blackscraper
you probably would like the battery pack stay warm while driving. when it is very cold (like a typical Canadian winter day), this 0.6kw-1.3kw might not be enough to keep both cabin and pack warm. Also this heat pump however efficient during "good weather", is not that so during such cold when heat is most needed. Beginning of 2020, we southern Ontarians experienced a streak of cold days when night temperatures dropped to -25C(real temperature not "feels like") and daytime high hovering around -10C. If heating does not guarantee a "far worse range" than EPA, then what about crosswind/headwind? To make matters worse, northwest wind blew at 25km/h and gusting to 45km/h at the same time. I can see from your profile you also live in Quebec. I think winters there are harsher there than Southern Ontario.An EV can also draw on wasted heat and the new Octovalve system in the Y does exactly that. Now the difference between a BEV and an ICE car is that in the ICE car the wasted heat is 500% of the traction load whereas in a BEV it may be 5 - 10%. Going down the highway at 70 mpH an X may be pulling 13 kW meaning 0.65 to 1.3 kW is being wasted. That is plenty to heat the cabin and warm the battery until it starts to get more than a little cold. When it gets more than a little cold the heat pump in the Y and presumably the CT will cut in returning 300 W of heat for each 100 W of battery invested.
I'm not saying that there aren't circumstances where the cold is going to be an appreciable factor but especially with the new Y "plumbing" this situation is going to improve in that regard. As it is the fleet sees an average of 10% efficiency loss in winter.
