firsttruck
firsttruck said:I see no evidence of metal being heavier.
Those numbers are not weight of steel vs ALON armor glassA) 305 stainless steel is 7.99 g/cm^3 while ALON is 3.696 g/cm^3
Those numbers above are rates (mass density, weight per volume).
** the bottom line is 3mm steel weighs a LOT LESS than 12mm Alon armor glass **
** 95.9 kg for 3mm stainless steel vs 187 kg for 12mm armor glass roof & support frame
** You can not use 3mm/6mm or 8mm of armor glass at a size of 2-meter by 2-meter **
** see below for detailed calculations **
There are two issues with the numbers you gave:
1. The numbers are mass density, only the weight for a cube of 1cm x 1cm x 1cm.
Basically the numbers are the density.
The "cm^3" part is volume.
2. The volume of material need to do approximately the same job or protection is vastly different.
To get close to 3mm 30x cold-rolled stainless steel you need approx. 12mm-15mm of aluminum oxynitride. Before aluminum oxynitride the best glass material would have required a thickness of 20mm and much heavier. Aluminum oxynitride 12mm thick is still less protection than 3mm SS metal.
aluminum oxynitride 1cm (10mm) x 200cm x 200cm
Size of window 200 cm (6.56 ft) x 200 cm (6.56 ft)
Area 40,000 cm^2 = 200 cm x 200cm (43.0336 ft2)
thickness of glass roof: 1.2 cm ( 12 mm)
total volume: 48,000 cm^3
density of aluminum oxynitride 3.696 g/cm^3
weight: 177,408 g ( 177.4 kg - 391.1 lbs)
You can not weld armor glass to 3mm steel. You also can not just glue heavy piece of armor glass to sides of hole in a 3mm sheet of steel.
You need like a L shaped metal frame for the glass to rest on.
You have to weld this frame to the other roof or side walls
then put glue/sealant on the support frame, then position the glass in the hole and frame and finally finish with more glue/sealant.
Well this support frame for the glass adds extra weight too.
Stainless 300 series L strip bracket .3 cm (3mm) x 800cm x 5cm
volume 1,200 cm^3
weight: 9,588 g ( 9.6 kg ( 21.2 lbs )
187 kg (412.3 lbs) total weight for armor glass roof & support frame
Making the frame and attaching the frame is extra the fabrication I mentioned before.
All this takes time and is more steps that need to be done. And the sealant/glue needs time to set too so more slowdowns.
Even if metal roof was an option not the default putting in a 2x2 metal piece is much easier because you do not need the frame to support the metal piece. You can just directly weld the metal roof piece to the other parts of wall or roof and no waiting after welding is done.
Metal roof
Cold-rolled Stainless 30x series sheet .3cm (3mm) 200cm x 200cm
Size of window 200cm (6.56 ft) x 2cm (6.56 ft)
thickness of glass roof: .3 cm ( 3 mm)
total volume: 12,000 cm^3
density of 305 stainless steel is 7.99 g/cm^3
weight: 95.9 kg ( 211.4 lbs)
