- Crissa
- Jul 8, 2020
- Santa Cruz
- 2014 Zero S, 2013 Mazda 3
A) that weighs alot more than the glass they're using.How about 3mm cold-rolled 30x type stainless steel?
B) that would transfer more stress from damage to the frame.
C) more weight transfer to the frame means more likely to total the vehicle.
The armor glass isn't thin. It will be thicker than the stainless steel sides.
Cracked glass can be replaced easily. Bent steel has to be cut out, and has a higher chance of transferring damaging loads to the frame.
Lastly, you keep assuming 3mm steel is cheaper than the armor glass. That's not in evidence, actually.
And yes, the armor glass is harder than than hardened stainless steel. 'Glass' and 'steel' do overlap, so a hardened steel point will scratch basic glass. But ceramic glass and sapphire are harder than even that. And hardened stainless is still not as hard as a cobalt point.
PS, the cabin of a Tesla is designed to save you, not the vehicle, in event of damage to it. So you really don't want weigh transfer to the core passenger capsule, that will total the vehicle.
