firsttruck
The issue is not to have a metal veneer for looks.How much metal is really required here? Why not just adhere a thin sheet of metal (like the thickness of aluminum foil) to the already existing glass?
The glass roof makes the vehicle more expensive to fabricate and takes more time to make
glass roof will cost owners more over the life of the vehicles
( Yes, not every owner will have a direct repair incident but over all vehicles there will be higher costs. The place most owners will see this is that insurance has to be higher to cover the higher costs)
glass roof vehicle are harder to mount accessories and other equipment on.
Things like antennas, light bars, special police/fire/emergency equipment, racks.
Can you drill a hole in glass roof without cracking the $1,000 glass roof ?
Can you drill hole in armor glass roof?
Is there special process to drill a hole in glass roof?
Will you trust the installer to drill without cracking your glass roof? How do you get the installer to pay for replacement if roof cracks?
Will most installer not even offer installation on glass roof because they do not want to be liable.
There are already installers & mechanics that refuse to work on Teslas.
Glass roofs have more seams that can leak water. If you search Internet you find many incidents of leaky roofs.
( Yes, metal roofs can leak too. The problem is that glass roof have more seams than standard metal roofs).
What about if a medium size rock falls from high cliff, bridge, overpass, building and cracks the armor glass roof.
A cracked glass roof absolutely will need to be replaced.
The same rock incident would dent a 3mm cold-rolled stainless steel. The owner could safely decide not to get the dent fixed.
Radio antennas for transmitters do not work well on glass roofs.
Business owners of Cybertruck should not have to pay more for Cybertruck because of glass roof.
About 25% of vehicles are used by businesses. There are probably a lot of non-business owners that also would like to save $1,000 on Cybertruck and save on insurance.
Truck owners that do not need a transparent roof or just believe that money ($1,000) could be better used on other things should not have to subsidize those that want such an expensive ($1,000) luxury item.
