- Crissa
- Jul 8, 2020
- Santa Cruz
- 2014 Zero S, 2013 Mazda 3
This is not true. There would be no reason to use an AC inverter - and even if you did, the minimum Tesla step is 700W (5a), not 1.4kW - for the incoming DC power. You would just need MPPT modules to step the voltage to the battery. They will need this for the solar tonneau in the first place.You'd need enough solar to run a 2KW inverter continuously, minimum charge rate is 1.4KW AC.
