SD2012
- Steve
- Jun 7, 2020
- Western NY
- Model 3 AWD
Sad to say, I don't even know what Starlink does - or will do. GPS?
I'm not sure it will have paint options. The exoskeleton is dent proof and if you smack the side of it with something it will leave a mark of some sort. Unless they have scratch proof paint....lol.Here are my predictions;
1) Aftermarket wheels and tires
2) Vehicle wrap
3) Paint factory wheels arches/flares
Yes there is a lot of debris up there. The Starlink satellites are designed to de-orbit and burn up completely in the atmosphere when they lose the proper function. Elon Musk also talked about the de-orbiting starlink satellite functioning as a debris collector on the way down. This could solve a lot of the debris problem.Many say that we are now polluting the skies with space junk just like we have polluted the earth. Tons of articles on the subject.
Even the tiniest bits of space junk can cause damage
“At last count there were over 20,000 pieces of space junk larger than a softball, and about 500,000 larger than a marble orbiting Earth.
Scientists say there are many millions more too small to be seen and the number is growing all the time.
Even the tiniest fragments can cause damage — according to NASA flecks of paint led to a number of space shuttle windows having to be replaced.
It has even been suggested that at some stage the sheer number of bits of space junk will cause a "cascade" of collisions and could render an orbit unusable.“
Can you tell me more about this install. Brand used and if there are any tutorial videos? I've been thinking about doing this modification for a while.I will be adding a electric tint to side windows and sun roof. Those who dont know, electric tint is where with flick of a switch, tint turns to opaque or transparent. I like to have glass transparent in winter so sun can keep the car warm and summer the glass stays opaque so sun don't heat it up. I installed it in my current F450 in 2017 and it works like a charm.
I would love to see freewheeling and regenerate charging while towing.I would like to tow this behind a RV, so I'm hoping freewheeling will be a part of it
Unfortunately most of the space junk is probably aluminum and other non-ferrous materials. The other issue is the space junk is probably not all rotating around the earth in the same general direction. It is a problem and you have to wonder how many Starlink satellites will be hit as objects orbits degrade over time.I think we should send up a space magnet![]()
The engineers at Tesla I’m sure can develop an aluminum magnet ? and or giant net similar to a swimming pool net and scoop up all the crap floating around. ?Unfortunately most of the space junk is probably aluminum and other non-ferrous materials. The other issue is the space junk is probably not all rotating around the earth in the same general direction. It is a problem and you have to wonder how many Starlink satellites will be hit as objects orbits degrade over time.
