- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
That's a lot of trailer. It is 14000/2.2 = 6363.6 kg worth of trailer. Let's look at the easy part first: getting that 1 mile up. A mile is 1600 meters. The acceleration due to gravity is 9.8 m/sec^2 so to get that trailer up 1 mile you will have to put at minimum 9.8*6363.6*1600 = 9.97812e+07 joules of energy into it. A watt hour is watt for 3600 seconds i.e. 3600 joules so this job means 9.97812e+07 /3600 = 27717 kWh (from a, perhaps, 200 kWh battery).`-how to get my 14k minimalist kit 100 miles away and 1 mile up. But I totally get it.
Now the rest of the job of calculating how much energy is required is much trickier. The math is pretty straight forward. It is summarized at
https://www.cybertruckownersclub.com/forum/threads/cybertruck-towing-range.334/page-2
The problem isn't the math. It's knowing what numbers to put into it. For example with regen we just calculated that going up a mile requires drawing 27717 kWh from the battery and that coming down we should recoup much of that but we don't know what "much" is numericall (80% ?). And we don't know what the drag of the trailer is relative to the vehicle. Thus I have taken the approach of estimating that trailer drag, relative to truck drag is the ratio of their masses to the 2/3 power (justified by ratio of volume to surface area) and made other equally shaky assumptions 80% regen recovery) to prepare the chart in that post. It suggests that towing a 14,000 pound trailer up a 1% (1 mile in 100 miles) will result in reduction of range to 21% of the truck's EPA rated range i.e. it will result in a practical range of about 100 miles. Now we note that you don't charge the battery fully and then discharge it fully before recharging. Running between 10% and 90% i.e. about 80% of usable capacity is more reasonable and so your practical range with a trailer this big is about 80 miles. Also be aware that historical data collected from the Tesla fleet shows that drivers achieve between 86 (winter) and 93 (summer) % of the EPA range so at the higher end range will probably be reduced by another 7 % to around 75 miles. Also be aware that anything that increases consumption such as underinflated tires and, a big one, water on the road surface, will reduce range further.
Be aware that my chart is not going to give you an accurate prediction but is rather intended to give you a general idea of how grade and weight interact. Nevertheless my conclusion is that the CyberTruck is not the truck for pulling something as heavy as 14,000 pounds unless you can and are willing to recharge every 80 - 100 miles. You will have to decide whether this is acceptable or not.
That might work for you.I tow heavy locally with 60 mile round trips.
We can WAG this (but it will be a WAG). The range estimate for the CT plus 14000 lb trailer is 80 - 100 miles.The battery in the CT is going to be about 200 kWh and you are going to use a good part of that on a 60 mile trip. Thus your fill up cost is going to be a good part of 200 times the cost of a kWh of electricity. On average in the US that's 13 cents at home so $26 if you charge at home. At Tesla Super Chargers the average cost is about twice this so $52 is approximately what you will be paying if you charge on the road at SC's. If you have to use non Tesla chargers the cost may go up by another factor of as much as 2 which means that you will be paying more than you would for gas.Instead of spending 50 bucks filling up I would like to spend 25 on electricity. Or less.
Regen charges the battery and there are limits as to how fast the battery can accept charge, even without a trailer. It stands to reason that if you are towing something which triples the total mass of the system that regen is going to be limited. This will result in a dramatic reduction in range, especially in hilly country. Were I contemplating towing something this heavy with the CT this is something I would look at very closely.Also I’d like to use regen braking advantages when towing.
There are hundreds of videos and articles that go into this.i wish he would talk about in the video electrical energy generation efficiency, transmission efficiency, the difference in pollution, and the cost of electric fill up versus ICE.
If you charge from a clean source (nuclear, solar, wind, hydro) it has no impact other than the particulates from the tires. If you charge from a coal burning plant that's obviously not the case but it's still less than using a diesel vehicle.And what each trip to the mountains does to the environment.
It's definitely operating close to the boundaries of the envelope. I'd be extremely cautious.Towing 14k fifth wheels Is pretty fancy.
