- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
The problem with your argument is that it assumes first that aerodynamic drag is dramatically less in the CT relative to other vehicles and second that aerodynamic drag is the dominant load on trailer and tractor. Were both of these assumptions valid then what you are saying would be true.
As I said in an earlier post the math is simple enough. The ratio of range with the trailer to range without is
r = 1/(f + 1)
where f is, in turn, the ratio of the sum of all the loads on the trailer (numerator) to the sum of all the loads on the tractor (denominator). The problem, as I said in my earlier post, is that of finding numbers to put into the sums. In the simple case where we tow a CT with another CT we might posit that the loads were the same on both in which case f = 1 and r = 1/2.
In the more interesting case (towing a loaded trailer) the job of finding f is complicated by the fact that there are several loads to consider
A)Drive train losses
B)Wheel slip losses
C)Drag
D)Rolling resistance
E)Gravity
F)Inertia
G)HVAC, headlights, windshield wipers...
Note that the trailer is not subject to A, B, or G loads. Also note that two of the loads, E and F can be negative numbers so that f can be negative and the range with a trailer can be larger than the range without. This could be the case for the lucky operator whose business involves trailering granite blocks from a quarry at the top of a mountain to a construction site in the valley. Thus r can assume any value between 0 and ∞.
The relative (that is, relative between type within tractor or trailer and between tractor and trailer) importance of loads depends not only on the design of the vehicles but on how they are operated. If you are in heavy traffic or in town the inertial load is probably the greatest. If you drive at constant speed on the freeway on level terrain the inertial load goes away (except for the initial acceleration). If you drive at low speed in town the drag load is most likely going to be insignificant relative to the slip and inertial loads. If you drive fast enough drag may become significant as it increases with the square of the speed. If you drive in hilly country the gravitational load will assume importance. As an example of this the average (winter/summer/day/night/hot/cold) load on my X is 301 Wh/mi. Driving on a 1% grade increases that by 108 Wh/mi.
Now when I see Elon promising extra goodies for trailering I get all excited because I realize that a simple load cell in the trailer hitch would allow the vehicle to compute the numerator in f and the display, which in the current vehicles, shows Wh/mi vs. distance traveled could now have a second trace showing the Wh/mi for the trailer alone. This would be a very powerful tool. Reviews of trailers could list the kWh the trailer will consume under various test conditions. Owners would soon learn the demands of their trailers just as they soon learn the demands of their cars now. Probably an engineer's midsummer's night dream but it could be pretty cool if they did that.
r = 1/(f + 1)
B)Wheel slip losses
C)Drag
E)Gravity
F)Inertia
