- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
The CT comes with a V2H solution: the 240V receptacle in the bed of the truck. This can be wired to a transfer switch connected to an appropriately loaded sub panel which feeds things like refrigerators and well pumps in your house.... If you have a link to a commercial V2H solution I’d love to see it.
I don't believe it has been stated how much power will be available from that receptacle but given that the same bridge that charges the car could be used to supply that receptacle and that the semiconductors in that bridge support 11.5 kWh we can say that that receptacle could supply that much. But Tesla might not choose to use that same circuitry and may install an entirely separate inverter of lesser (or equal) capacity. It is also worth noting
1)That if you discharge a 185 kWh battery at an 11.5 kW rate it will be depleted in 16 hrs
2)Energy taken from the battery to run your house's air conditioner in no longer available to motor you out of Dodge should that become necessary.
