ct355
- Chris
- Feb 25, 2020
- 2020 Tesla Model 3 Stealth Performance, 2009 M/B GL450
CT will have half-shaft and fully independent air suspension. Portals are solid-axles much like you find on a Unimog or a farm tractor. These are for ultra-heavy duty work and lower the final drive ratio for more torque to the wheels. Cybertruck will have little use for this. Also, while they do multiply torque, they add weight, complexity, cost, maintenance and dramatically increase I sprung weight. But luckily the trick suspension on the CT will probably embarrass even the mighty Unimog off road: So fear not.Hi people, I was watching the CT unveil for the thousandth time and noticed something. When the truck went into loading mode (raises front while lowering back) to load the ATV, It seemed like the body raised above half of the wheel. Wouldn't that mean that it has portal axels? It's slight but I'm pretty sure I'm right. Here's the photo:
