May be cameras on trailers and magnetic wire harness with signal lights & cameras for towing.One advantage to conventional side mirrors is that if you forget to wipe them off, you can at least reach the driver's side mirror by simply rolling down the window and wiping it off with the edge of your hand.
The other issue with lack of mirrors comes with towing - you want a vantage point for the camera that is at least as wide as the trailer so you can see beyond the trailer which is likely wider than the truck. The cameras will need to be on some kind of extendable stalks.
Finally, with mirrors, you are already typically looking over that same side shoulder. Turning instead to a screen in the center console to see what is beside on your left is going to be a lot of head swiveling and could induce a b it of disorientation.
Interesting point. I would favor cameras only if there was a small screen on say, the left A-pillar and the right side, A-pillar. I most definitely would not approve if the left and right side view was on the same main screen in the center console of the car. That's just goofy. And unsafe.One advantage to conventional side mirrors is that if you forget to wipe them off, you can at least reach the driver's side mirror by simply rolling down the window and wiping it off with the edge of your hand.
In my F350, they do but they are heated.While I do wonder about this, do rearview mirrors stay clean in the same circumstances?
I expect cameras should work about the same as mirrors in adverse conditions, so it is a wash.
Why would the cameras need redundancy? I'm missing something. Is there redundancy for mirrors? No. I suppose you could tape another mirror over a broken/missing one but the car itself doesn't have redundancy. How often do you think the camera will break? I've seen tons of cars without mirrors on the road. They didn't stop driving because the mirror broke. I mean, they are so cheap to replace, why wouldn't they?You are stating the obvious, but mirrors don't lose power. Anyway, I never said I have a preference, only that mirrors cannot lose power (except to turn them I guess). As a mirror they won't fail. That is why I mentioned always being able to turn around and look. If I am a government agency I will look for redundancy in lieu of a mechanical solution, so if Tesla (or any other manufacturer) can provide camera redundancy, then maybe the powers that be will grant them a waiver. I don't know.
Just put an air knife in, the truck already has a compressor built in.And they may be heated to keep ice from building up
Why not just put additional camera on side of trailor ?I've got it!!!
Seriously... Those triangles that house the rear view cameras... What if they were on, say 12" stalks that deployed outwards when connected to a trailer to allow the cameras a better angle down the sides of the trailer? They could easily calculate the width of the trailer and deploy just enough to see past the trailer. The wide-angle camera view combined with the other ones already around the CT and ONE additional one that connected to the back of the trailer could give you a really good 360 view on the display... lets call it "Towing View". The mirrors would retract when stopped so people don't mess with them.
"Only use for Tesla compliant trailers with cameras".Why not just put additional camera on side of trailor ?
Well just like you can unsafely pull a trailor without extended mirrors.... but perhaps wireless trailor cameras? But doesn't seem like it would be much work to put cameras on trailor If the tractor had the connections..."Only use for Tesla compliant trailers with cameras".
Label on the tow hitch.![]()
