Cyber Larry
- Larry
- Jun 20, 2020
- Florida
- Jeep Wrangler & CyberTruck (on order)
- retired
So, need to unhook the trailer to get to the charger.... each time.
The charger isn't blocked by the trailer. There's just not alot of places to park at most chargers yet. Maybe eventually we'll have pull-through chargers. They're becoming more common in Northern Europe.So, need to unhook the trailer to get to the charger.... each time.
The top of the graph is the maximum consumption rate that the graph is designed to display. This appears to be about 600 Wh/km which is apparently well over twice the rated consumption for this car (hard to read the rated from the jiggly video but looks like about 160 Wh/km = 256 Wh/mi?). This is not a power graph. It is an energy consumption graph. The power meter is separate. The maximum power is drawn when the vehicle is going up hill and accelerating at high speed. An electric motor's torque vs speed curve is flat at low speed and then declines approximately linearly with speed above a break point which is at the maximum torque - maximum power point. Above that break point power is limited. Below it torque is limited. Towing a trailer at high speed one is not in the power limited region until one accelerates to the point where it is impossible to go any faster. Thus these guys never reached the maximum power output of the car.Also, in the part of the video where they show the power graph, it looks to be maxed out quite a bit of the time. How long can an M3 Tesla run at maximum output before things start to overheat? I cannot imagine the system is designed for 100% duty cycle at max output at max ambient temp. An electric vehicle with more total power like the CT would hopefully give more "headroom" of not being maxed out as much.
