Revoltlution
- Apr 7, 2020
- Portland, Or
- Website
- about.me
- Prius (CyberSlug)
- Automation Engineer
Hmmm, I LOVE how the CT tickles our engineering minds.I am just saying the outer "silhouette" can be stamped using a cutting die, no forming or shaping would be needed. The general shape of the flat panel can be stamped out of the sheet instead of being laser cut. This would be much faster and economical compared to the laser.
My guess is any stamp cutter would have a high operating cost maintaining the die/cutters and slow to make engineering changes, especially with this cold-worked stainless. I could be wrong, considering this is only 3mm.
[lasers vs stamping]
Lasers
- pro: reduced maintenance and clean process
- pro: repeatable, high tolerance and clean edges eliminates secondary operation
- pro: pro systems can easily cut <1" stainless (CT is ~3mm)
- pro: one machine (footprint) can cut any part and make just-in-time modifications
- con: cutting speed is slower then stamping, but proportional to watts!
- con: can change material's edge properties (color, hardness) due to heating
- pro: faster than lasers, especially with difficult materials
- pro: could combine shaping steps
- con: retooling time and money to make edits or add parts
- con: more tooling wear and maintenance
- con: cut quality can effect tolerances and fit/finish
