azjohn
- john
- Nov 21, 2019
- North Carolina
- Toyota Tundra
I have been following him for a while, I never knew he is off grid.
If it would be so inefficient, how would you ever run your AC home grid from it ???And he never gets into the inefficiency of changing the solar from DC to AC (up to -50%)
Inverter. Not the MPPT voltage tracker.If it would be so inefficient, how would you ever run your AC home grid from it ???
My converter sits right at the panel and has a rated efficiency that is much higher:
https://www.cybertruckownersclub.co...anned-can-the-grid-handle-electric-cars.2426/Maybe this is the place for my thoughts; Speaking in terms of Grid reliability and those cost associated with failure as seen most recently in Texas. What if; assume for a second that ICE vehicles give way to the battery powered vehicles in the future. What happens to the Grid when everybody gets off work at 5pm, travels home and plugs in their baby????
Most of the EVs, especially newer ones, let you plug it in, but set the time when it will charge.Maybe this is the place for my thoughts; Speaking in terms of Grid reliability and those cost associated with failure as seen most recently in Texas. What if; assume for a second that ICE vehicles give way to the battery powered vehicles in the future. What happens to the Grid when everybody gets off work at 5pm, travels home and plugs in their baby????
I am sorry to have been misunderstood.Inverter. Not the MPPT voltage tracker.
Inverters become very inefficient at low power uses. That's why many grid-tied systems are using many micro-inverters instead of a single inverter.
If you're putting it into a battery, you want to stay to that MPPT efficiency level, and not throw an on inverter and charger to get back to battery DC on top of it.
Thank you, my power company offers and I currently use the reduced TOU rate. Monthly average is at .18 per kWh? I’ve not researched others to see how my rate compares.Most of the EVs, especially newer ones, let you plug it in, but set the time when it will charge.
And, given the huge drop in rate and usage of electricity at night, I am sure many power companies will be happy to sell power at night when the grid is under utilized compared to during the day.
This is something that is bandied about a lot, adjusting for this would not be as big a deal as many think it is.
There are many videos from many different views. I have compared a few different perspectives and it looks like that by the time we even get to 50% conversion to EVs the grid could grow to compensate for the 100% conversion in the same time frame.
I am very interested in a PV system and was quoted panels with micro inverters. The single most important issue to me was; “I was told that I would not have power if the grid was down”. That in itself killed the deal. I want power if/when the grid fails. I want to be responsible for my own power reliability. Any advice would be greatly appreciated and I feel this is important to the success of all CT owners.@Crissa
My system is based on micro-inverters with integrated MPPT for each module.
I do not use a battery (total cost inefficient and we have practically no power outages where I live ).
The BEV will only be charged (>2kW-11kW) during peak PV production times, with Surpluspower that would normaly go into the grid (no Netmetering avilable in Germany).
IMHO this will be the way PV systems will evolve for safety, plugandplay, efficiency, controlability and scaleability reasons.
If you like to look at your app, to monitor your system, you will be very happy to have this controll at the module level. It makes maintanance and trouble shooting much easyer.
Even if you put your Solar DC direct in you EV the voltage has to be transformed, granted with less loses than inverting AC-DC.
People thinking of getting a PV system should inform them selve about micro-inverters, there have been a lot of innovations and cost reductions in this area.
Most of the PV Install companys will not give you those new informations.
They like to install what they know and makes profit for them.........
reminding me of ICE Car salespeople that do not tell you the truth about BEV......
We are all human after all.
No, no, your system is safer and more efficient to have the microinverters and controllers for each panel segment! But it's also more costly up front than a single inverter.I am sorry to have been misunderstood.
This question is best answered by examining what electric utility folks call the Duck Curve. The Duck Curve is the graph showing how demand for electricity varies throughout the day.Maybe this is the place for my thoughts; Speaking in terms of Grid reliability and those cost associated with failure as seen most recently in Texas. What if; assume for a second that ICE vehicles give way to the battery powered vehicles in the future. What happens to the Grid when everybody gets off work at 5pm, travels home and plugs in their baby????
